2 Replies Latest reply on May 1, 2014 4:07 AM by roberto gennari
    IModeler CopyWizardHole Method
    roberto gennari
      has anyone had experience with:
      Dim instance As IModeler
      Dim SourceHole As System.Object
      Dim DestinationHole As System.Object
      Dim RebuildOwner As System.Boolean
      Dim value As System.Integer
      value = instance.CopyWizardHole(SourceHole, DestinationHole, RebuildOwner)
      what is it called this Api?
      Thanks to all
      Roberto
        • Re: IModeler CopyWizardHole Method
          Artem Taturevych
          Hello Roberto,
          This method copies all properties (except of location points) from one hole wizard feature to another one and also renames the destination feature according to new profile. Here is an example which copies all attributes from first selected hole wizard feature to second selected hole wizard feature. I'm not sure why this method appears under the IModeler interface IFeatureManager is more appropriate I think, but anyways.
          Dim swModeler As SldWorks.Modeler
              Set swModel = swApp.ActiveDoc
              Set swModeler = swApp.GetModeler
              Dim swSourceHole As SldWorks.Feature
              Dim swDestHole As SldWorks.Feature
              Set swSourceHole = swSelMgr.GetSelectedObject6(1, -1)
              Set swDestHole = swSelMgr.GetSelectedObject6(2, -1)
              swModeler.CopyWizardHole swSourceHole, swDestHole, True
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
