I was trying to import a (.sat) format file in SolidWorks.
The component was automatically getting scaled up than its normal size.
Can anyone suggest me a solution.
R.Vignesh
R.Vignesh
When you are importing files it is important to note that you need to select the type of file you are importing in the open file dialog box, this will cause the "Options..." button to appear. You can then select the units the imported file is using (meters, inches, etc.) as well as other import options. If you switch back to "All Files (*.*)" the "Options..." button will remain. I think the fact that it's not there to begin with is a minor bug, but I've never bothered to pursue the matter.
