2 Replies Latest reply on Apr 28, 2014 2:54 PM by Thomas Hellm
    A marco that can change custom properties
    Thomas Hellm
      I have an project and I want to change all of the part numbers. The change will be adding 1000 to them i.e. #23 will become #1023. I have not writing a VB program in many years and have found sample codes I can use to help solve this issue but I can figure out how to make the program get the old part number so I can just add the 1000 to it and create a new number.
        • Re: A marco that can change custom properties
          Keith Rice
          Thomas,
          The following code must be run with a part open. It will extract the value of a custom property called "PartNo". If that value has a pound sign, it will be stripped. 1000 will be added, then the PartNo custom property will be reset with a pound sign on the front again.
          Dim swCustPropMgr As SldWorks.CustomPropertyManager
          Dim strPartNo As String
          Dim dblPartNo As Double
              Set swModel = swApp.ActiveDoc
              If swModel Is Nothing Then Exit Sub
              If swModel.GetType <> swDocPART Then Exit Sub
              Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
              strPartNo = swCustPropMgr.Get("PartNo")
              strPartNo = Replace(strPartNo, "#", Empty)
              If IsNumeric(strPartNo) = False Then Exit Sub
              dblPartNo = strPartNo
              dblPartNo = dblPartNo + 1000
              swCustPropMgr.Set "PartNo", "#" & dblPartNo
          I am sure that you can modify this macro for your own needs. Please mark this answer as correct if it helped.
          Keith
          SolidWorks API Tutorials
