2 Replies Latest reply on Apr 29, 2014 8:16 AM by Mark Coville
    Delete Top Level Macro
    Mark Coville
      Does anyone have a macro that deletes the top level of what is selected. We just upgraded from SW2011 to SW2014 and this new delete functionality is not the best thing for us .(especially with EPDM) Here is what I have so far. I don't know how to select the top level of each component. Any help would be great
      Dim swApp               As SldWorks.SldWorks
      Dim swModel             As SldWorks.ModelDoc2
      Dim swSelMgr            As SldWorks.SelectionMgr
      Dim swSelComp           As SldWorks.Component2
      Dim NewObjToSelect      As Object
      Dim GeneralSelObj       As Object
      Dim swParent            As Object
      Dim selObjectsCount     As Integer
      Dim i                   As Integer
      Dim CurSelCount         As Long
      Dim boolstatus          As Boolean
      Set swModel = swApp.ActiveDoc
      CurSelCount = 1
      selObjectsCount = swSelMgr.GetSelectedObjectCount
      For i = 1 To selObjectsCount
          Set GeneralSelObj = swSelMgr.GetSelectedObject(CurSelCount)
          Set swSelComp = swSelMgr.GetSelectedObjectsComponent(CurSelCount)
          Set NewObjToSelect = swSelComp.GetParent
          If Not NewObjToSelect Is Nothing Then
          swSelMgr.DeSelect CurSelCount
          bRet = NewObjToSelect.Select(True)
          Else
          CurSelCount = CurSelCount + 1
      Next
      End
        • Re: Delete Top Level Macro
          Artem Taturevych
          Hi Mark,
          Try this macro:
              Dim i As Integer
              For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
                  Set swComp = swSelMgr.GetSelectedObjectsComponent3(i, -1)
                  If Not swComp Is Nothing Then
                      Dim compsToDelColl As New Collection
                      Dim swParentComp As SldWorks.Component2
                      Set swParentComp = swComp
                      While Not swParentComp Is Nothing
                          Set swComp = swParentComp
                          Set swParentComp = swComp.GetParent
                      Wend
                      If Not CollectionContains(compsToDelColl, swComp) Then
                          compsToDelColl.Add swComp
              Next
              swModel.ClearSelection2 True
              For i = 1 To compsToDelColl.Count
                  Set swComp = compsToDelColl.item(i)
                  swComp.Select4 True, Nothing, False
              Next
              swModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Children
          Function CollectionContains(coll As Collection, item As SldWorks.Component2) As Boolean
              Dim i As Integer
              For i = 1 To coll.Count
                  If coll.item(i) Is item Then
                      CollectionContains = True
                      Exit Function
              Next
              CollectionContains = False
          End Function
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
