Hello, guys I was wondering if anything could be found wrong in my application of load or fixtures?
I applied load on the top and fixtures on the bottom.. anything is wrong here?
p.s. how do you change the direction of the fixture or load?
Hi Danny,
From the Screen Shot your put in the forum, You defined Shrink fit in assembly,i think so. I could not get you where you have applied Shrink fit and What is the function of the Assembly why you have fixed Bottom. You just explain function of your assembly and Contact conditions. So that its easy to Give solution or work aroun for your problem.Thanks
Regards,
A.D.Kumar,
EGS India,
Chennai,
India.
CSWP-Advance Nonlinear, Dynamic, Motion, CSWS Simulation, CSWP -FEA.
