1 Reply Latest reply on Apr 28, 2014 8:16 PM by Artem Taturevych
    3dsketch points virtual sharp corner
    Vijayakumar Pitchai
           I am creating tube model in solidworks API (using X,Y,Z coordinate points in 3dsketch,fillet and sweep features).  After that , I got all the 3d sketch points from model  through .Getsketchpoints2 function.
      But, Output of this function x,y and Z coordinate points are not in sequence.
      Also, how can i identify the center and virtual sharp corner points of Arc and except construction geomentry lines coordinates.(filter the construction line coordinates).
        • Re: 3dsketch points virtual sharp corner
          Artem Taturevych
          Hi  Vijayakumar,
          Welcome to SolidWorks API Community!
          The points returned in the sequence they were created. It is all up to you to sort them. You can use the SketchSegment::ConstructionGeometry to filter the centerlines. In regard to arc properties you can convert ISketchSegment to ISketchArc (just cast it) and you can find the methods like SketchArc::GetCenterPoint2 which returns the center point of the arc. You can also get the end points to calculate virtual sharp.
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
