3 Replies Latest reply on Apr 29, 2014 9:28 PM by Artem Taturevych
    trying to login to PDMworks
    Craig Makarowski
      Hi all, had this work once today now its broken when it gets to
           connection.Login "pdmwadmin", "pdmwadmin", "localhost"
      I'm currently using SW2013 SP5 and Win 7 x64
      AM I missing something fundamental?
      I have my Environment Varible pointing to the correct place for SW2013 for the PDMworks dll
      Code as follows from an example
      Option Explicit
      Dim swApp As Object
      Dim swModel As ModelDoc2
      Dim swModelPart As ModelDoc2
      Dim swModelAssy As ModelDoc2
      Dim swModelDocExt As ModelDocExtension
      Dim swModelDocExtPart As ModelDocExtension
      Dim swCustProp As Object 'CustomPropertyManager
      Dim connection As PDMWConnection
      Dim user As String
      Dim password As String
      Dim Vault As String
      Dim value As Integer
      Dim doc As PDMWDocument
      user = "pdmwadmin"
      password = "pdmwadmin"
      Vault = "loclhost"
           ' connect to pdmworks and login
           Set connection = CreateObject("PDMWorks.PDMWConnection")
          Dim alldocs As PDMWDocuments
          Set alldocs = connection.Documents
          Dim adoc As PDMWDocument
          Dim msgBoxStr As String
          For Each adoc In alldocs
              If LCase(Right(adoc.Name, 6)) = "sldprt" Then
                  msgBoxStr = msgBoxStr & "Part: " & adoc.Name & vbNewLine
                  msgBoxStr = msgBoxStr & "Assemblies where it is used:" & vbNewLine
                  Dim whereUsedList As PDMWLinks
                  Set whereUsedList = adoc.WhereUsed
                  Dim l As PDMWLink
                  For Each l In whereUsedList
                      If LCase(Right(l.Document.Name, 6)) = "sldasm" Then
                          msgBoxStr = msgBoxStr & "    " & l.Document.Name & vbNewLine
                          Debug.Print msgBoxStr
                     ' Stop
                  Next
                  msgBoxStr = msgBoxStr & "----" & vbNewLine
          Next
          'Output.data = msgBoxStr
          'Output.Show
          connection.Logout
