3 Replies Latest reply on Apr 25, 2014 10:24 AM by Nick Salters
    LocalLPattern in subassembly
    Nick Salters
      I am trying ot modify a LocalLinearPattern in a subassembly.  I can do it fine when I open the subassembly and write code to modify it there, and the only real difference is what goes in to the Part.Extension.SelectByID2() portion, so I assume that is where I am having the issue.  I don't think I am properly selecting the local pattern within the subassembly.  Any help would be greatly appreciated.
      My tree looks like this:
      TopAssembly
           -NextAssembly<1>
                -LocalLinearPattern1
      Code looks like this:
      Sub AlterPart()
          Dim swApp As Object
          Dim pPart As Object
          Set pPart = swApp.ActiveDoc
          Part.ResolveAllLightWeightComponents (True)
          Dim Skip2(0 To 50) As Long
          Dim boolstatus As Boolean
          Dim lFeatureData As ILocalLinearPatternFeatureData
          Dim pFeature As IFeature
          Dim pSelMan As SelectionMgr
          Erase Skip2()
          Skip2(0) = 42
          Skip2(1) = 43
             boolstatus = Part.Extension.SelectByID2("LocalLPattern1@NextAssembly-1@TopAssembly", "COMPPATTERN", 0, 0, 0, False, 0, Nothing, 0)
              Set pSelMan = pPart.SelectionManager
              Set pFeature = pSelMan.GetSelectedObject5(1)
              Set lFeatureData = pFeature.GetDefinition
              lFeatureData.SkippedItemArray = (Skip2)
              pFeature.ModifyDefinition (lFeatureData, pPart, Nothing)
              lFeatureData.ReleaseSelectionAccess
          Part.EditRebuild
          Part.ClearSelection
        • Re: LocalLPattern in subassembly
          Artem Taturevych
          Hi Nick and Welcome to the SolidWorks API Community!
          I would suggest to not select by composed name. It is better to find the pointer directly. When you modifying the definition in context you should pass the pointer to component as the context object. Please find the code below which is applicable to your case.
              Set swAssy = swApp.ActiveDoc
              ModifyLinPattern "NextAssembly-1", "LocalLinearPattern1"
          Sub ModifyLinPattern(compName As String, pattName As String)
              Set swComp = swAssy.GetComponentByName(compName)
              Dim swFeat As SldWorks.Feature
              Set swFeat = swComp.FeatureByName(pattName)
              Dim swFeatData As SldWorks.LocalLinearPatternFeatureData
              Set swFeatData = swFeat.GetDefinition
              swFeatData.AccessSelections swAssy, swComp
              Dim skipArr(1) As Long
              skipArr(0) = 1: skipArr(1) = 3
              swFeatData.SkippedItemArray = skipArr
              swFeat.ModifyDefinition swFeatData, swAssy, swComp
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Nick Salters
              Thanks for the assistance, my biggest problem was understanding the component2 method and then what the AccessSelections method wanted in terms of parameters.  In addition to this, I saw that the Modify Definition should automatically release the selection, and I added the release selection after that anyway, but in the model after my code runs, the subassembly is still "Open" for editing.  Is there a way to have it "close" for editing.  Not sure if I'm making sense here, but basically it leaves it where the SubAssembly is Opened and I want it closed after the code runs.
              Other than that the model is updating as it should.  Thanks again!
