I would like to create a Design Table template with the custom properties added for configuration-specific custom properties. I tried creating a template with the fields started:
$PRP@PARTNUMBER
$PRP@TITLE
etc. (see attached)
The problem is that the table doesn't automatically fill in with the sketch properties of the part "D1@Sketch1, D2@Sketch1, etc."
I would like to have this table in the Part template to make it foolproof for the engineers who are just starting to learn design tables
If I create a new part from scratch and used the auto-create, the table wizard gives me a list of dimensions I can add to the table. Is there a way to refresh the table to insert the dimensions?
Brad
You can put columns for D1@Sketch1 and D2@Sketch1 in the design table template, if you want. Or, if you don't want to use a template file and instead want a prompt to add any dimension, you must edit that dimension and choose the "This DImension" option.
Dwight
