4 Replies Latest reply on Apr 25, 2014 9:26 AM by Peter Houwen
    VBA get comps by component reference
    Peter Houwen
      I am working with Printed Circuit Board assemblies (from PADS Layout through Circuitworks).
      I need to make a VBA call from PADS Layout VB to select or get a component in Solidworks using it's Component Reference.
      i.e., I have resistor "R12" selected in PADS, I want to also select it in Solidworks.
      I can't seem to find a get or select that allows me to filter by the Component Reference.  I will need to do this for quite a few parts, so I would rather not loop through a few hundred components in Solidworks for each reference designator if I don't have to.
      Pete
        • Re: VBA get comps by component reference
          Artem Taturevych
          Try this macro:
          Const COMP_REF As String = "R12"
              Set swAssy = swApp.ActiveDoc
              Dim vComps As Variant
              vComps = swAssy.GetComponents(False)
              Dim i As Integer
              swAssy.ClearSelection2 False
              For i = 0 To UBound(vComps)
                  Set swComp = vComps(i)
                  If swComp.ComponentReference = COMP_REF Then
                      swComp.Select4 True, Nothing, False
              Next
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Peter Houwen
              Artem,
              Thanks, but that's what I was trying to avoid.  I could have hundreds of components, so I would need to do that hundreds of times.  That's why I'm looking for a way to select by the reference.
              boolstatus = Part.Extension.SelectByID2(...... here's where I tried using ComponentReference
                  Keith Rice
                  Peter,
                  I have experience writing macros that process huge assemblies. If your assembly is a few hundred components, and you only have to run this macro occasionally, you should be fine.
                  If you have to run this macro many times within the SAME assembly, and during that time you are not adding new components that would need to be searched for, then the macro could be modified to generate a list of all component names and their corresponding reference numbers and store that data as a string in an invisible attribute (or even in a text file on your hard drive if you wanted). When the macro is run, it will first see if this attribute exists. If yes, then it will search the attribute string for the component reference you specify and select the associated component using IModelDocExtension::SelectByID2. Unless you had thousands of pairs in the string, the search would be nearly instantaneous to you.
                  Keith
                  SolidWorks API Tutorials
                      Peter Houwen
                      It looks like I'll have to do it the long way.  That's not a huge problem, I just get frustrated when I know there is information in there and I can't access it!  I was hoping someone knew an undocumented object.
                      I ended up storing the values I want to look for in an array, since that's a smaller set than the components in the assembly.
                      Thanks, all!
                      Pete
