Vincent Bunker
PDM Will Not Allow Column  Read From File on Check in
Discussion created by Vincent Bunker on Feb 12, 2007
Latest reply on Feb 13, 2007 by 1-71SUYO
Just Changed to SWX 2007 from 2006.
When I attempt to check in an assembly and slelct the revision column then read from file, the revision will only read from the 1st file; I receive the error, "Revision type not found or invalid." for the rest of the files
We do not use life cycle. The only driving feature that we use is working copy default. Both PDM Vault and PDM Client are on the same service pack 2.2.
