I created a master part file with many seperate bodies and then right clicked on the solid bodies and clicked "insert in to new part".
Somehow a few of my parts now have broken references and are unable able to update when I change the master part file, and there is no sketch in the part because it was created from the master so I'm unable to modify it at all.
Is there a way to get those references back? The only way I could figure how to do it was to recreate the part again and overwrite the existing broken part. This is not the ideal method because most parts have many other features done to them once created as a part.
Thanks - Jim
SW2013 SP4.0
Jim
One approach would be to roll back to first feature and insert your master part there using Insert / Part. Delete the unwanted bodies, then shift all the references to the new body. Major work, but maybe better than nothing.
I find that SolidWorks easily loses track of body identity. I don't know if that is what happened in your case, but it might be. I prefer to insert the entire master part and delete bodies for just that reason. It allows me to reselect the bodies.
Dwight
