Is it possible to project 3D curve on a solid face?
Actually I am trying to project a 3D curve on a sphere but I fail.
Please suggest me any idea(s) about these type projection.
I am using SolidWorks-2013.
Thanks and regards,
Kamlesh
I'm not sure if it will work but give the wrap command a try.
Chris
Hi Chris,
It's not working.
AS I know wrap only able to work on cylindrical face.
Create Datum plane perpendicular to the direction of projection. Convert 3D curve to 2D in that plane and project the 2D curve on a sphere.
Hi Jan,
Please explain your point more clearly.
I am disable to follow it.
You can analyze this part. It maybe helps you.
It is very clear, Thanks, Jan,
