Hi Everyone,
I have been asked to find a way to create animated 3d pdf to help with the assembly and disassembly of our products. I have managed to created the animation in SW 2013 (I am not a SW user, just manipulating existing parts to create assemblies) but the animation can only be saved as video file, which is huge and undesirable. Not to metion the fixed camera view and not being able to zoom, pan and rotate throughout the animation. I also have tried saving the file with exploded view as u3d but when I tried to imported to PDF file, the animation does not play. It is there though because if I drag the slider bar slowly I can see it explode. Strangely a guy in youtube did the same thing with SW 2012 and his animation was playing fine.
My end goal is to having something like the attached PDF file. Can Solidworks Composer create this?
Thanks in advance.
Van,
Here is another link that will show you Composer animation being used in a PDF along with view usage also. I wouldn't know the file size of the finished product but it does give you a clear idea of Composer in PDF form. In this example the end user does have some control but I would think you could customize it to work for you. You wouldn't get the quality of video from my previous post but this may be a mid point for you to keep your PDF requirements. Perhaps you can show your VAR this example and see if they can find you someone in your area doing this type of PDF animation work you could speak to for step by step direction.
https://www.youtube.com/watch?v=qPy9xf4oz3M
Derek
