I've never run into this before, but, but maybe some of you have.
I have a client that wishes to have the defining circle of a Detail View displayed as a center line or a phantom line. I cannot get SW to provide this. If I edit the skecth and make the circle construction geometry, it give me the error
and closes the sketch with the solid line as before. If I start with a construction line circle and then select the Detail View I get the same error. I've tried other irregular shapes as well--same thing. The construction line option is cancelled after you exit the sketch, so that if you try and edit it again it's gone.
I know it seems like a picky thing, but when they ask for it, you'd like to be able to give it to them.
I'd appreciate hearing from anyone with the same experience, a workaround, or certified solution.
Thanks!
