2 Replies Latest reply on Apr 17, 2014 9:01 AM by Glenn Schroeder
    Angular Relations
    Matt S.
      Hey,
      I can't seem to figure this out but is there a way I can set angular relations between multiple angles that I all want to be equal (Excluding the basic parallel and perpendicular).
        • Re: Angular Relations
          Chris Michalski
          If you select the dimensions you can RMB and Link Values so that they are equal.  Or use equations to define them equal to a variable.
            Glenn Schroeder
            You could also do it with construction lines.  In the screenshot the two construction lines that are closest to vertical are equal, and the other two are equal, with their endpoints coincident with the midpoints of the ones going across.  As you can see the construction lines aren't fully defined yet, but they have the angles fully defined as equal after dimensioning one of them.
