2 Replies Latest reply on Apr 17, 2014 6:19 AM by Vallen Vallen
    Hello,how can i change my sketch text font format by the VBA, i cannot understand the explain of the help of api file,
    Vallen Vallen
      it can run in my computer , the following VB code is ok,now ,my problem is what should i to add in my code,and i can change the fontname by the add code.
      is there someone used it before ?
      thank you !
      Private Sub Command1_Click()
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = CreateObject("SldWorks.application")
      swApp.Visible (True)
      Set Part = swApp.Newpart()
      Set Part = swApp.ActiveDoc
      Dim myModelView As Object
      Set myModelView = Part.ActiveView
      boolstatus = Part.Extension.SketchBoxSelect("0.000000", "0.000000", "0.000000", "0.000000", "0.000000", "0.000000")
      boolstatus = Part.Extension.SelectByID2("上视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
      Part.SketchManager.InsertSketch True
      Part.ClearSelection2 True
      Dim skSegment As Object
      Set skSegment = Part.SketchManager.CreateCenterLine(0#, 0#, 0#, 0.01, 0#, 0#)
      boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, False, 1, Nothing, 0)
      Dim mySketchText As Object
      Set mySketchText = Part.InsertSketchText(0, 0, 0, "OK", 0, 0, 0, 100, 100)
      Part.ShowNamedView2 "*上视", 5
      Part.ViewZoomtofit2
