Create a macro to save the current view of a part as a DXF
Question asked by Jacob Suther on Apr 16, 2014
Latest reply on May 31, 2014 by Deepak Gupta
This is my first macro that I have tried to create. I am trying to create one that will take the current view of a part and save it as a dxf. I have seen some that export the flattened pattern of a sheet metal part as a dxf, but I am not working with sheet metal so this is not applicable. I recorded a macro of me going to save as and selecting dxf and the current view which resulted in this:
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
longstatus = Part.SaveAs3("\\2014-04-16\test.DXF", 0, 0)
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameLeft = 0
myModelView.FrameTop = 22
myModelView.FrameState = swWindowState_e.swWindowMaximized
Set Part = swApp.NewDocument("\\Ansi B.drwdot", 0, 0, 0)
swApp.ActivateDoc2 "Draw4 - SHEET 1", False, longstatus
swApp.ActivateDoc2 "test.SLDPRT", False, longstatus
Dim myView As Object
Set myView = Part.CreateDrawViewFromModelView3("C:\Users\user\Desktop\test.SLDPRT", "*Current", 0, 0, 0)
boolstatus = Part.DeleteNamedView(*Current) 'There is a syntax error here
Part.ClearSelection2 True
The editor shows a syntax error at boolstatus = Part.DeleteNamedView(*Current), if I comment this line out and run it gets hung up on the line above it with the error of "Object doesn't support this property or method". Any help would be appreciated.
