5 Replies Latest reply on Apr 16, 2014 1:20 PM by Christopher Estelow
    Centerline continuation
    Ian Hoven
      Does anyone know of a way to continue connection lines when placing new center marks on different holes.  When I place multiple center marks and have the connection lines button checked all of the parallel and perpendicular holes automatically get a connection line between them.  The problem starts  when I stop placing center marks and come back to it later and want to continue, or if I add a new hole to the part.
      My workaround now is to apply a second center mark to a hole that already has the connection line and start back up again.  It seems that there should be an eaier way to continue the centerlines.  The only other option that I have found was to remove all of the center marks and start all over.
        • Re: Centerline continuation
          Mark Kaiser
          Don't know of another way other than what you have mentioned.  Need the 'add to stack' functionality of balloons.
            Dwight Livingston
            Ian
            Please vote for the following ERs
            553342 Provide ability to edit a Linear Center Mark to add holes.
            611218  Ability to reattach (re-attach) dangling centerlines and centermarks in a drawing view (center lines center mark)
            650355 Provide a separate gap control in document properties for the distance between a dimension extension line and a center mark
            Dwight
            edit: updated the links (that's a touchy editor)
            edit: I don't know why the last two numbers would not take my edits. you'll have to look them up
