AMAaron Moncur15/04/2014
I am creating a drawing to be used in a patent, so it is line drawing format, no color or shading. However, I need one of the components in the assembly to be see-through in order to visualize the parts behind it. Is there a way to change the display style of only a single component in the assembly from "hidden lines removed" to "hidden lines visible" so that the part becomes see-through? Better yet, is there a way to change the "material" properties of the component in a drawing so that it is clear and I can then visualize what is behind it in the assembly?
