Non-Uniform Pressure Distribution for Radial Relationships
Question asked by Wayne Spritz on Apr 14, 2014
Latest reply on Apr 15, 2014 by Jared Conway
Does Simulation offer a non-uniform pressure distribution with polar coordinates instead of a quadratic based?  I have two flat discs sealing in compression which fluid pressure breaks down from the OD to the ID.  The pressure drop can be determined most easily by assigning a radial relationship... hence the polar coordinate system would the easiest answer.  If not then how can I use the cartesian coordinate system for a circle with the constants only being assigned to either a liner or a parabolic relationship (only goes to x^2 or y^2).
Also, I noticed that the axisymmetric 2D simplified simulation does not offer non-uniform distribution.  This would be so nice to have in my circumstance where the pressure is normal to a disc surface and changes via a radial distance relationship.
Is there another "place" where I can enter my own equation from scratch?
Thanks!!
