3 Replies Latest reply on Apr 13, 2014 3:34 PM by Solidworks Selim
    axis of the macro delete
    Solidworks Selim
      delete centerline macro
      How to delete all at once
      file is attached.
      http://www.dosya.tc/server28/CbIkBh/DELETECENTERL_NEMACROS.rar.html
          • Re: axis of the macro delete
            Artem Taturevych
            Try this macro:
                Set swDraw = swApp.ActiveDoc
                Set swModel = swDraw
                swModel.ClearSelection2 True
                Dim swSheet As SldWorks.Sheet
                Set swSheet = swDraw.GetCurrentSheet
                Dim vViews As Variant
                vViews = swSheet.GetViews
                Dim i As Integer
                For i = 0 To UBound(vViews)
                    Dim swView As SldWorks.View
                    Set swView = vViews(i)
                    Dim vCenterLines As Variant
                    vCenterLines = swView.GetCenterLines
                    If Not IsEmpty(vCenterLines) Then
                        Dim swCenterLine As SldWorks.Centerline
                        Dim j As Integer
                        For j = 0 To UBound(vCenterLines)
                            Set swCenterLine = vCenterLines(j)
                            Dim swAnn As SldWorks.Annotation
                            Set swAnn = swCenterLine.GetAnnotation
                            swAnn.Select3 True, Nothing
                        Next
                Next
                swModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
            ______________________________________________
            Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
            IC3DSteel – New Steel Solution for SolidWorks
            translationXpert – SolidWorks files language translator
            LinkedIn - SolidWorks API Group
