I'd like to simulate a tube which has a water mass flow rate 0.21 kg/s and inlet temp is 340K. also there is a cross flow air over the tube externaly whose temp initialy is 288 K and velocity 20m/s. Thus I wanna see the fluid temp distribution thorugh the tube but i cant simulute that. I choose external flow analys and insert fluid subdomain as water in tube. also specify the tube material as aliminum. after i calculated i get the uniform 340K temp inside the tube. Pls can u help me about this ?
Emre, I suapect that the drop in water temperature is so small you are just not seeing it. Try setting the results scale to a very narrow band (like 340K to 339.9K) and see if that will show the temperature gradient in the water.
