Our company has a digitzer from proliner in which it will create a 3d drawing that can be exported as a DXF file. Alot of people with this spedicific digitzer import there data into Rhino in which you can edit. For me however I have been using solid works for years now so it is kind of a challenge to use Rhino so I want to be able to import the DXF into solid works and edit the drawing. The problem when I import the file right now into Solid works as a part I end up with a bunch of of imported curves that I cannot edit.
Does anyone have any suggestions on how I can clean up these drawings? I attached a file that I am working with.
