I have created a master profile part that will be used in many different parts.
When reopening the new part file, this profile part is delinking (>?), although I have did not have any issues with placing the part in the part file. I did not select break link when inserting the part. but it does not link when I reopen the file... I can select open the part and then the parts relink but, cannot have this for other users as they would not want do as such every time the file is to load.
Please assist?
Whenever you are working with a part inside of a part, Solidworks wants the referenced part to be open to check for changes. For whatever reason, it's not as nice and clean like an assembly file that will just rebuild when you open it. Here's what you can do.
If you go to your system options here...
You can pick how Solidworks will act when opening these parts...Prompt - it will ask the user, All - it will automatically open all needed referenced parts, None - it will not open any referenced parts - (will show the "?" saying it's out of context) or Changed Only - only open if something as changed in that referenced part - (will most likely also show the "?").
I hope this helps.
