2 Replies Latest reply on Aug 12, 2015 4:55 AM by Jan Forkovic
    Surface bodies in design tree
    Blandine Ganivet
      Hi everybody,
      I would like to know if it's possible to select all the components in the folder Surface bodies which are in the design tree?
      Thank you for your help
        • Re: Surface bodies in design tree
          Keith Rice
          Hi Blandine,
          The following code will accomplish this. Please note that I have given you two options for selection. One will select the bodies in the display area but not the feature tree, the other will select in both. Please comment the line you don't want.
          I used the attached part for my testing.
          Dim swFeat As SldWorks.Feature
          Dim swBodyFolder As SldWorks.BodyFolder
          Dim swBody As SldWorks.Body2
          Dim vBodies As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              swModel.ClearSelection2 True
              Set swFeat = swModel.FirstFeature
              Do While Not swFeat Is Nothing
                  If swFeat.GetTypeName = "SurfaceBodyFolder" Then
                      Set swBodyFolder = swFeat.GetSpecificFeature2
                      vBodies = swBodyFolder.GetBodies
                      For i = 0 To UBound(vBodies)
                          Set swBody = vBodies(i)
                          'Option 1: Select bodies in display area but not in feature tree
                          'swBody.Select2 True, Nothing
                          'Option 2: Select bodies in display area and in feature tree
                          swModel.Extension.SelectByID2 swBody.Name, "SURFACEBODY", 0, 0, 0, True, 0, Nothing, 0
                      Next i
                      Exit Do
                  Set swFeat = swFeat.GetNextFeature
              Loop
          Hope this helps.
          Keith
          SolidWorks API Tutorials
