6 Replies Latest reply on Apr 14, 2014 11:50 PM by Allen Liu
    How to get selected edge object in PartDoc?
    Allen Liu
      I met a problem about select edge object in partdoc. When it be selected, but it cannot get object.
      It's very odd.
      public class PartEventHandler : DocumentEventHandler
              PartDoc doc;
              public PartEventHandler(ModelDoc2 modDoc, SwAddin addin)
                  : base(modDoc, addin)
                  doc = (PartDoc)document;
            override public bool AttachEventHandlers()
                  doc.DestroyNotify += new DPartDocEvents_DestroyNotifyEventHandler(OnDestroy);
                  doc.NewSelectionNotify += new DPartDocEvents_NewSelectionNotifyEventHandler(OnNewSelection);
                  ConnectModelViews();
                  return true;
      public int OnNewSelection()
                  //for test case //add date:2014/04/10
                  ModelDoc2 mDoc = (ModelDoc2)doc;
                  //SelectionMgr selectionMgr = null;
                  ISelectionMgr selectionMgr = (ISelectionMgr) mDoc.SelectionManager;
                  if (mDoc != null)
                      selectionMgr = mDoc.SelectionManager;
                      int selectedObjectCount = selectionMgr.GetSelectedObjectCount2(-1);
                      // needs elaborate SWITCH based on selection type.
                      if (selectedObjectCount == 1)
                          swSelectType_e selectionType = (swSelectType_e)selectionMgr.GetSelectedObjectType3(1, -1);
                          //retrieve feature expecting type with GetFeature()
                          //dynamic entity = selectionMgr.GetSelectedObject6(1, -1);
                        object entity = (object)selectionMgr.GetSelectedObject6(1, -1); //why cannot get edge and always return null?
                          string retName = mDoc.GetEntityName(entity);
                          System.Windows.Forms.MessageBox.Show("Name is " + doc.GetEntityName(entity) + ".");
                         swtch (selectionType)
                              case swSelectType_e.swSelSKETCHPOINTS:
                                  System.Windows.Forms.MessageBox.Show("Sketch point.");
                                  break;
                              case swSelectType_e.swSelEDGES:
                                  System.Windows.Forms.MessageBox.Show("Edges");
                                  break;
                  return 0;
        • Re: How to get selected edge object in PartDoc?
          Simon Turner
          Your file seems corrupt - I cannot open it.
            Amirtharaj Vk
            Hi Allen:
            I have written a code to get length of the selected edge. The code is below. It will help you to get selected edges.
            using SolidWorks.Interop.sldworks;
            using SolidWorks.Interop.swconst;
            using System.Runtime.InteropServices;
            using System;
            namespace Allen.csproj
                public partial class SolidWorksMacro
                    ModelDoc2 mDoc;
                    ISelectionMgr selectionMgr;
                    swSelectType_e selectionType;
                    Entity swent;
                    Edge swedge;
                    Curve swcur;
                    Double edgelen;
                    CurveParamData  curparam;
                    int selcount;
                    public void Main()
                        mDoc = (ModelDoc2)swApp.ActiveDoc;
                        if (mDoc != null)
                            selectionMgr = (ISelectionMgr)mDoc.SelectionManager;
                            if (selectionType == swSelectType_e.swSelEDGES)
                                swent =(Entity) selectionMgr.GetSelectedObject5 (1);
                                swedge =(Edge) swent;
                                swcur = (Curve)swedge.GetCurve();
                                curparam = (CurveParamData)swedge.GetCurveParams3();
                                edgelen = (Double)swcur.GetLength3(curparam.UMinValue,curparam.UMaxValue) * 1000;
                                System.Windows.Forms.MessageBox.Show("Selected Edge Length (mm): " + edgelen);
                    /// <summary>
                    ///  The SldWorks swApp variable is pre-assigned for you.
                    /// </summary>
                    public SldWorks swApp;
            Regards
            V K Amirtharaj
            EGS Computers India Pvt Ltd
            http://www.egsindia.com
            http://www.egs.co.in
              Allen Liu
              I merge your code into my add-in. It's work very fine. Thanks a lot.
