Folks,
I need some advice on my computer. I have been having some issues (described below)
System:
00013 | Xi® MTower™ PCIe Workstation (Base Configuration) | $1,119.00 |
01819 | Intel® Core™ i7 3770K @ 4.5GHz Silent Sealed Water Cooling 8MB Shared L3 Cache DMI Quad-Core 3rd Gen. 22nm | $439.00 |
02260 | 16GB DDR3 1866MHz Corsair® Vengeance Heatspread | $239.00 |
04444 | AMD® FirePro™ V4900 1GB DDR5 PCIe 1xDVI Dual Link- 2x Display Ports Dual Monitor Support | $189.00 |
05015 | No Monitor (credit) | ($140.00) |
03147 | 120GB Solid State Drive Corsair® Force Series™ 3 (R2) SATA 6Gb/s 550/520MB/s Seq.R/W SandForce® SF-2200 Ctrl. <.3ms seek Shock Resistant 1500G. | $69.00 |
32120 | Optional 120GB Solid State Drive Corsair® Force Series 3 (R2) SATA 6Gb/s 550/520MB/s Seq.R/W SandForce® SF-2200 Ctrl. <.3ms seek Shock Resistant 1500G. | $129.00 |
17012 | HD Ctrl. According To Motherboard and HD Type Selected | Incl. w/ Base |
23011 | SATA/SAS Trays accordingly to case selected | Incl. w/ Base |
06019 | DVD 16x40x Reader | Incl. w/ Base |
09007 | On-Board sound accordingly to motherboard specifications | Incl. w/ Base |
12001 | On-Board Network port accordingly to motherboard specifications | Incl. w/ Base |
13017 | No Keyboard | ($8.00) |
14001 | No Mouse | ($8.00) |
16084 | Genuine Microsoft® Windows® 7 Professional Edition 64Bit on DVD (32Bit & XP Pro downgrade avail. on request) | $59.00 |
21039 | Genuine Microsoft® Office 2010 Home and Student Edition License MLK (No Media/XP-64, educational & Home use Only) | $119.00 |
22269 | Asus® P8Z77-V LE Intel® Z77 Express C.S-1xPCIe 3.0/2.0x16-1xPCIe 2.0x16(x4)-1xPCIe 2.0x1-Dual Ch.DDR3 2400(OC)/1333-1xGb Ethernet-2xSATA6Gb-4xSATA3Gb RAID 0/1/5/10-Digital Audio-8CH-S/PDIF-10x/2xUSB 2.0/3.0-1xeSATA-DVI-HDMI-DisplayPort | Incl. w/ Base |
44030 | 850W Corsair® TX Series Ultra-Quiet BB 14cm Fan 80%+efficiency 99% Active PFC | $59.00 |
27157 | Xi® MTower™ CM-Elite™ 430 2x12cm Quiet Fans-Front Grid-2x Front USB- 3x 5 1/4" 7x 3 1/2" (No O.C. & Single CPU MoBo only) | Incl. w/ Base |
18001 | Standard Xi Warranty w/Express Advance Parts Replacement, One Year on System, Mfg. on Monitor | Incl. w/ Base |
43001 | Energy Star™ Enabled. Can be disabled/enabled at any time in the OS Power Mgmt. | Incl. w/ Base |
47002 | NEMA 5-15P to C13 Wall Plug, 125 Volt, 16AWG, 5 Feet. Standard Computer AC power Cord | Incl. w/ Base |
It started with graphics issues. The screen would hang up with a small "view box" in the center of the screen in which I could see the data moving. I figured it was the video card so I replaced the card with a AMD W5000. The new video did not fix the problem. As time has gone on the computer has become slower. One major issue I have is that there is serious mouse lag. I will move the mouse, wait a half second or so and then the mouse starts to move. The same thing with the keyboard. If I type a sentence the computer will loose the first half of the sentence and then catch up and write the rest.
What I have done to try to fix:
1. Re-installed windows.
2. Ran mem test.
3. Defragged drives.
Another engineer in my office suspects it is the power supply, so I have a new one on order.
Beyond that, where do I go?
Tim
The small window is indicative of NOT using an Aero theme.
Are you still using SW2009 per your avatar profile?
Have you run the SolidWorks Rx > Diagnostics tool?
