1 Reply Latest reply on Apr 10, 2014 6:58 PM by John Sutherland
    Measure distance to lofted surface
    John Sutherland
      I want to measure the vertical distance from an edge. vertex or horizontal face of a brick to the surface of the ground.
      The measure tool allows me to select suitable references but fails to calculate.
      I have tried several workarounds but they all fail.
      Is it possible to measure to a lofted surface?
        • Re: Measure distance to lofted surface
          John Sutherland
          I solved my problem by opening a sketch on the end face of the slab and requesting an intersection line between the sketch plane and the lofted ground surface.
          After creating a virtual sharp where the intersection line cuts the vertical sketch line, I could dimension and measure the depth of fill between natural ground and the underside of the slab.
