SRSamuel Raybin09/04/2014
When using a corporate document template, which typically uses inches, I am unable to properly specify the unit precision in milimeters for (.1). In other words, 2.0mm is displayed as 2mm even when I adjust the unit precision in a number of ways. I have tried to adjust many settings in Document Properties or the Dimension pane and I have been unable to find a fix. I can adjust the unit precision to (.12) or (.123) and it properly displays as 2.02mm or 2.024mm. If i create a drawing with the blank template, I also have no issue displaying (.1) unit precision. I am uncertain as to whether this is a bug or a drawing template issue, or whether there is some setting that can be changed. Any help would be appreciated.
