Hey everyone!!
Basically I've got two different extrudes in my part that are too complex to draw as sketches and then loft between the sketches, using a guideline. I've had a quick hunt around + can't find anything that describes how to do what I want.
I've attached the file which probably makes is more clear than what I've explained, basically the two extrudes at either end are what I want lofted together + the 3D sketch that's just hanging around is the guide curve
Thanks very muchly!!
Laura
Laura,
Where the extrudes are planar, all you have to do is select the face, start a new sketch on it then, with the face still highlighted, select convert entities. You'll now have the profile sketched.
You can also invoke the loft command, right click on the edge of the profile, selection manager and that will select the outer edge as well (you may have to change the direction).
Boss-Extrude5 will need to be merged with Boss-Extrude4 for this to work on both extrusions.
The guide curve you have didn't work. I threw one in along Boss-Extrude1 to get the results shown in the picture. I've attached the file, too.
