I am trying to create a belt feature across three bearings, and from what I can tell, the software will not draw the belt as it should.
I have attached a screenshot below. As you can see, the middle bearing is a problem, with the belt being drawing through the cirumference, rather than around. I am using SW 2014 SP2, though I have just upgraded and therefore may be missing something in this version.
If anyone could help me with this issue, I would be very grateful.
As an update to this, the whole belt builds perfectly when I put a fourth axis into the feature. It looks like it's just a bug that there's not going to be a fix to. I can find a workaround, but I'd much rather have this model working as is should, so any help would still be appreciated
