2 Replies Latest reply on Feb 6, 2015 10:17 AM by Yong Ning
    How to move the design table
    Yong Ning
      paste excel in drawing, follow code is true, but design table in drawingdoc , follow code is error.
         Dim swOleObj As SldWorks.SwOLEObject
         Dim xlObj
         Set swModel = Application.SldWorks.ActiveDoc
         Set swOleObj = swSelMgr.GetSelectedObject5(1)
         Debug.Print swOleObj.FileName
         Set xlObj = swOleObj.SetActive(True)
         Debug.Print xlObj.Name
        • Re: How to move the design table
          Artem Taturevych
          Here is the macro which locates design table in the drawing to specified location (0, 0 by default)
          Const EXCEL_WORKSHEET_CLSID As String = "{00020830-0000-0000-C000-000000000046}"
          Const TARGET_X As Double = 0
          Const TARGET_Y As Double = 0
              Set swModel = swApp.ActiveDoc
              Dim vOleObjs As Variant
              vOleObjs = swModel.Extension.GetOLEObjects(swOleObjectOptions_e.swOleObjectOptions_GetAll)
              Dim i As Integer
              For i = 0 To UBound(vOleObjs)
                  Set swOleObj = vOleObjs(i)
                  If swOleObj.Clsid = EXCEL_WORKSHEET_CLSID Then
                      Dim vBounds As Variant
                      vBounds = swOleObj.Boundaries
                      Dim width As Double
                      Dim height As Double
                      width = vBounds(3) - vBounds(0)
                      height = vBounds(1) - vBounds(4)
                      Dim dBounds(6) As Double
                      dBounds(0) = TARGET_X: dBounds(1) = TARGET_Y: dBounds(2) = 0
                      dBounds(3) = TARGET_X + width: dBounds(4) = TARGET_Y + height: dBounds(5) = 0
                      swOleObj.Boundaries = dBounds
              Next
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Yong Ning
              Private Sub ll4()
                Dim Wk As Workbook, Sht As Worksheet, Rng As Range
                Dim ii, Str, swApp As SldWorks.SldWorks
                Dim SwModel As ModelDoc2, SwDraw As DrawingDoc
                Set SwModel = swApp.ActiveDoc
                Dim Rr, Cc
                Set Wk = GetOLEObjectsToWk(SwModel)
                Set Sht = Wk.Sheets(1)
                With Sht
                  Rr = .Range("A65536").End(3).Row
                  Set Rng = .Range("A4:A" & Rr)
                  'Debug.Print Rng.Address
                End With
                'Debug.Print Rng(1, 20), Rng(1, 26)
                For ii = 1 To Rng.Rows.Count
                   Str = Rng(ii, 1)
                   With SwModel
                     .Extension.SelectByID2 Str, "CONFIGURATIONS", 0, 0, 0, False, 0, Nothing, 0
                     .ShowConfiguration Str
                     .ViewZoomtofit
                     .ForceRebuild3 False
                   End With
                   'Stop
                Next ii
                'SwModel.Quit
              Private Sub ll5()
                Dim Rr, Cc
                With Sht
                End With
                   Str = """SW-Material@@" & Rng(ii, 1) & "@ttmpJB4721.SLDPRT"""
                   Str = """SW-Material@@" & Rng(ii, 1) & "@" & SwModel.GetTitle & """"
                   'Debug.Print Str
                   'Stop
                   Rng(ii, "Q") = Str
                   'Str = """SW-Mass@@" & Rng(ii, 1) & "@ttmpJB4721.SLDPRT"""
                   Str = """SW-Mass@@" & Rng(ii, 1) & "@" & SwModel.GetTitle & """"
                   Debug.Print Str
                   Rng(ii, "R") = Str
                Next ii
                'Stop
                'SwModel.Quit
              Private Sub ll1()
                Dim Xls As Excel.Application, Rng As Range
                  Set Xls = GetObject(, "Excel.Application")
                  Set Rng = Xls.Selection
                Dim Path, FileName, Wk As Workbook, oRng As Range
                Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                  Set SwApp = Application.SldWorks
                  Set SwModel = SwApp.ActiveDoc
                 Dim SwOleObj As SwOLEObject, vOle, vv As Long
                 vOle = SwModel.Extension.GetOLEObjects(vv)
                 Set SwOleObj = vOle(1)
                 Set Wk = SwOleObj.SetActive(True)
                  Set oRng = Wk.Sheets(1).Range("A2:Z1000")
                  oRng.Clear
                  Rng.Copy
                  oRng.PasteSpecial xlPasteValues
                  oRng.Font.Size = 9
                  Stop
                  SwOleObj.SetActive False
                  SwModel.ForceRebuild3 True
                Dim SwDesgTab As DesignTable
                  Set SwDesgTab = SwModel.GetDesignTable
                  Stop
                  With SwDesgTab
                     .Attach
                     Stop
                     .Detach
                  End With
