I try to import STEP-assembly exported from SolidEdge using "Merge file into one actor per part" in import settings.
However this doesn't seem to affect to anything. I still get hierarchy where under each part there is sub-object "Object 1" on next level etc.
This messes the BOM totally.
Question: How do I import STEP-assembly correctly with "one actor per part" ?
Thanks.
-Mike
I have tried some combinations of the import option and am finding similar behavior that you are. You can work with this in your tables by using the parent level pull down in the BOM Workshop. Create a new profile and set your parent level to 1. The the BOM IDs will be applied based on the parent node to the selected geometry.
