I have upgraded my laptop and installed Solidworks and everything looks great except...when I open an assembly, the parts list is incomplete. Solidworks queries me for the location of every missing component until the assembly is once again complete. Everything works fine at that point but I can't do this for every assembly. If the locations of the component parts aren't stored in the assembly file, where else would that information be? Thanks for any ideas.
It sounds like your assembly has lost all its references. Did you change any of your file/folder structure without using Solidworks Explorer? Like just dragging and dropping file onto your laptop? When you open an assembly, SW looks for the location of each aprt and subassembly file. If they are moved (like with Windoes Explorer) the references will be lost and must be re-established (like you've been doing).
