How to create the right square spiral?
If I use the deformation of the curve to curve geometry is distorted.
If you can open files from JM then great else check this video: http://www.youtube.com/watch?v=Upi4YQw4Ukk
You forgot to attach your attempt here and made no reference to answering that question.
Can you attach your *.slprt file here. The same one you posted an image of?
Can you explain how your design intent is different than the example I posted?
Without more information I'm not sure how to achieve a solution.
Do you have an actual object you are trying to reproduce?
Can you find a picture of something similar somewhere on the internet and provide the url?
What release of SolidWorks are you using?
2012? 2013? 2014?
Can you attach your initial attempt (*.sldprt) here?
Interesting that Rev1 doesn't sweep.
