Is there a way to delete data paths in SWComp prefs? It keeps making Composer folders in places I don't want them. I added a path to my desired location and even edited the data path xml file but I still get the extra folders everywhere. I even get 3DVia folders. Any help would be appreciated. It stumped my VAR.
SW Composer will generate a local User folder for every machine that SW Composer is installed on. This folder is where new profiles will be created. Typically, I use this as a sandbox for new profiles. Once the profile is the way I want it, I will edit the file and change the value of the <Profile.Modifiable> element to 0. Once saved I will move the file over to the common folder for all to use. This process allows me to "lock" down the profiles that are public. My sandbox can then be cleared as needed.
-Earl
