14 Replies Latest reply on Apr 4, 2014 2:22 PM by Matthew Elgie
    Error when using swDocPART in VB.NET
    Matthew Elgie
      Could some one help me with understanding why this is erroring and what I can do to fix it? I tried leaving it out, but everytime I try to use the add-in it just crashes.
      This is taken directly from the Solidworks API Help, but there is no explenation is swdocPART is a place holder, or if it is different in newer versions of Visual Studio.
      And I am at a loss on how to fix this, nor can I locate any posts really covering this.
      Imports SolidWorks.Interop.sldworks
      Imports SolidWorks.Interop.swconst
       Module OpenPrt
          Dim swApp As SldWorks
          Dim swModel As ModelDoc2
          Dim swSelMgr As SelectionMgr
          Dim swDocSpecification As DocumentSpecification
          Dim sName As String
          Dim Control1 As UserControl1
          Dim sLocation As String
          Sub OpenStrtPrt()
              swApp = New SldWorks
              sLocation = Control1.StartParts1.SelectedValue
              swDocSpecification = swApp.GetOpenDocSpec(sLocation)
              sName = swDocSpecification.FileName
              swDocSpecification.DocumentType = swDocPART
              swDocSpecification.ViewOnly = False
              swDocSpecification.Silent = True
              swModel = swApp.OpenDoc7(swDocSpecification)
              longstatus = swDocSpecification.Error
              longwarnings = swDocSpecification.Warning
      End Module
        • Re: Error when using swDocPART in VB.NET
          Artem Taturevych
          Try
          swDocSpecification.DocumentType = swDocumentTypes_e.swDocPART
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Matthew Elgie
              That took away the Error in my code. but it is still crashing.
              I looked at my output file and saw this:
              "at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)</ExceptionString></Exception></TraceRecord>
              The program '[4108] SldWorks.exe' has exited with code 1 (0x1)."
              I can't find any direct infor on debugging this though.
              I am thinking has something to do with having my Add-in connect with Solidworks.
                  Artem Taturevych
                  You need to identify what exactly the line which crashing SW. You can also try to use ISldWorks::OpendDoc6 instead of OpenDoc7.
                      Matthew Elgie
                      Alright-
                      So what it looks like is it crashes on
                      The location is being pulls from a Combo box that is connecting to a simple SQL server on my computer.
                      Do SW Task Pane Add-ins have issues with connecting to a SQL sever to get pathing?
                          Artem Taturevych
                          Put this line in try-catch block and make sure that Control1 and StartPrats1 are not NULL
                              Matthew Elgie
                              Is this what I am looking for from the Try-Catch block?
                              A first chance exception of type 'System.NullReferenceException' occurred in Solidworks VB.Net Addin Test.dll
                                  Artem Taturevych
                                  Yes, it says that some of your variables is Null
                                      Matthew Elgie
                                      Okay, so I did some testing with it.
                                      I have a msg box that showed the file path straight from the form
                                      Public Class UserControl1
                                          Private Sub On_Load(sender As Object, e As EventArgs) Handles MyBase.Load
                                              'TODO: This line of code loads data into the 'Start_Part_TestingDataSet.Start_Parts' table. You can move, or remove it, as needed.
                                              Me.Start_PartsTableAdapter.Fill(Me.Start_Part_TestingDataSet.Start_Parts)
                                          Dim swApp As sldworks.SldWorks
                                          Private Sub Create1_Click(sender As Object, e As EventArgs) Handles Create1.Click
                                              MsgBox(StartParts1.SelectedValue)
                                      And then tried so use that one, vs the msg box in the Module:
                                      Sub OpenStrtPrt()
                                              MsgBox(sLocation)
                                      ____________
                                      The first Displays the File path fine:
                                      The 2nd crashed Solidworks.
                                      I was thinking maybe I need to pass the information through a text box. The idea being that the text box can display the path to ensure tha the value is there, and then pass it to the module from there. But I can't figure out how to have the text box outfill with the file path.
                                        Matthew Elgie
                                        Nope still crashes.
                                        So it seems the information isn't passing between my Form to my Module?
                                        Any clue as to why?
                                        Here is my form for reference:
                                        Imports System.Runtime.InteropServices
                                        Imports System.Data.SqlClient
                                        <ComVisible(True)> _
                                        <ProgId("Solidworks_VB.Net_Addin_Test")> _
                                                Call OpenStrtPrt()
                                              Friend Sub getSwApp(ByRef swAppIn As sldworks.SldWorks)
                                                swApp = swAppIn
                                             Private Sub UserControl1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
                                              Private Sub StartParts1_SelectedIndexChanged(sender As Object, e As EventArgs) Handles StartParts1.SelectedIndexChanged
                                              Private Sub Run1_Click(sender As Object, e As EventArgs) Handles Run1.Click
                                                TextBox1.Text = StartParts1.SelectedValue
                                              Private Sub TextBox1_TextChanged(sender As Object, e As EventArgs) Handles TextBox1.TextChanged
                                             Public Sub New()
                                                InitializeComponent()
                                          End Class
