I am attempting to pick up routing as we have a seat but no one here uses it. I have watched the tutorials and am now attempting to create my first harness. In preperation I am placing connecting points and route points in components. However in the bellow view I am totally unable to select any points or vertex to locate the point. I placed a point in the center of the hole in the sketch, can't pick it. Placed a point feature in center of hole feature, can't pick it. Created an axis, can't pick it, Tried lassoing any vertex near the hole, no success. What do I need to do?
Thank you
If you are in part modeling, you should be able to create CPoint by selecting the edge of the hole. By selecting it, it should place the CP at the center of it. No need for any other reference. I beleive in your case, you can create two CPoints at the both sides of the bracket/lifting lug. You could also create a sketch with points, as Philip suggested. That's not a bad idea if you plan to have more CPs in one part.
On the other hand, if you are trying to crste ACPoints & ARPoints, you need to create a sketch deicated for these points.
