Hi guys,
I have this face I want to extrude up to a plane.
Problem is, a part of it has curvature I don't know how to sketch (don't have the original sketch for that).
Is there some way to extrude a face without sketching its edges on?
Or maybe a way for solidworks to automatically take the edges of that face and create a sketch on the same face with that data?
Pic attached
Thanks!
Hi Shar,
If you start a 2d sketch on the face you have highlighted in the picture (assuming this is flat) then with the face still selected inside the sketch, you should be able to use the "convert entities" tool on the sketch toolbar to 'copy' the edges of the face into the new sketch.
You will then be able to extrude as normal
Regards
Russell
