1 Reply Latest reply on Apr 10, 2014 10:14 AM by Jesse Seger
    how to import values from excel file
    Vishaldeep Singh
      hello
      i want to take the co-ordinates values of a point from excel file and take the values untill blank row comes.
      i was trying one code but there is some error i am writin the code below can any one debug it.
      the code will run only when the excel file is open.
      '''''' code'''''''
      Dim swApp As Object
      Dim Excel As Object
      Dim i As Integer
      Dim xpt As Double
      Dim ypt As Double
      Dim zpt As Double
      Set swModel = swApp.ActiveDoc
                  Excel = GetObject(, "Excel.Application")
                  swModel = CType(swApp.ActiveDoc, ModelDoc2)
                  swModel.SketchManager.Insert3DSketch (True)
                  Dim skPoint As SketchPoint
                  swModel.SketchManager.AddToDB = True
              Do While Excel.cells(i, 1).Text <> ""
                  xpt = Excel.cells(i, 1).Value
                  ypt = Excel.cells(i, 2).Value
                  zpt = Excel.cells(i, 3).Value
                  skPoint = swModel.SketchManager.CreatePoint(xpt, ypt, zpt)
                  i = i + 1
              Loop
              swModel.SketchManager.InsertSketch (True)
              swModel.SketchManager.AddToDB = False
        • Re: how to import values from excel file
          Jesse Seger
          You're very close.  Here is the updated code.  Make sure you add a Reference to the Microsoft Excel Library in Tools -> References.
          Dim swSketchMgr As SldWorks.SketchManager
          Dim swExcel As Excel.Application
          Dim exSheet As Excel.Worksheet
          Dim i As Integer
          Dim xpt As Double
          Dim ypt As Double
          Dim zpt As Double
              Set swExcel = GetObject(, "Excel.Application")
              Set exSheet = swExcel.ActiveSheet
              Set swSketchMgr = swModel.SketchManager
              swSketchMgr.Insert3DSketch (True)
              swSketchMgr.AddToDB = True
              i = 1
              Do While exSheet.Cells(i, 1).Value <> ""
                  xpt = exSheet.Cells(i, 1).Value
                  ypt = exSheet.Cells(i, 2).Value
                  zpt = exSheet.Cells(i, 3).Value
                  Set skPoint = swSketchMgr.CreatePoint(xpt, ypt, zpt)
                  i = i + 1
              Loop
              swSketchMgr.InsertSketch (True)
              swSketchMgr.AddToDB = False
