How do i model 3.25-8 ACME- RH acme thread in solidworks?
It is external thread..not sure how to start one
I believe that going off the information in the attachement on my post above the attached model should be correct for what you need.
If anyone sees differently please let me know.
Chris
The angle per side is 14deg30" for the trapezoid. The height of the trapezoid is half of the pitch which in this case would be .0625". The width of the bottom of the trapezoid is .3707 x pitch which is .0463". It is all on the first page of the pdf I attached on the detail shown below and the table that says Acme Form Basic Dimensions.
Hope this helps
Chris
You can check out a simple blog post I made that shows how to calculate Stub Acme or Acme dimensions based on the Machinery Handbook and also links to a Mathcad sheet you can download if anyone is interested in learning how to calculate the values them self. I also made a post on my blog in detail about how to create a User Defined Feature in Creo for Stub Acme thread forms. I didn't include the tooth profile but you would follow the steps in my blog plus the steps above to make a Library Feature in Solidworks to do the same thing. Things like Stub Acme threads that you model everyday should be made into some sort of easily usable macro type feature that you don't have to redo every part you design. Just Google steventaitinger stub acme if you are interested.
Generate a shaft of the correct OD.
Generate a Helix with the correct pitch.
Sketch the tooth profile.
Sweep cut profile along helix.
