I have a Circular Pattern in my Assembly with 50 instances, and I can't figure out how to get each one to move separately. Is it possibly? It will be awful if I have to mate them separately.
Try using a sketch pattern as they are a lot more flexible. Or, try dissolve the CirPattern, fix all, then adjust the ones you need to move. I'm not sure why you would want to move separately, that defeats the purpose of a pattern. But either way the methods above should allow the flexability. Cheers!
