7 Replies Latest reply on Apr 7, 2014 2:18 AM by Stanley Sentoso
    Asking about SelectByID2 function
    Stanley Sentoso
      Hi All,
      I'm a newbie in SolidWorks API and I have a question about the strange behaviour of SelectByID2 function. Below is the scanario:
      First of All, I created a sketch on solidworks and named it with "My_Sketch". Next, I created a very simple VBA macro to find (select) that sketch as following script
      Option Explicit
      Dim obApp As SldWorks.SldWorks
      Dim obPart As ModelDoc2
      Dim bStat As Boolean
          Set obApp = Application.SldWorks
          Set obPart = obApp.ActiveDoc
          bStat = obPart.Extension.SelectByID2("My_Sketch", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
          MsgBox "Return value is " & CStr(bStat)     ' Prompt the return value
          If bStat = True Then
              MsgBox "System found the sketch!"
          Else
              MsgBox "System couldn't locate the sketch!"
      when I run that script, it prompted me "Return value is True" and "System couldn't locate the sketch!"
      By right, if bStat is True, it will prompt "System found the sketch!" but it didn't.
      Is it a bug or have I implemented wrongly ?
      FYI, I used SolidWorks 2013
      TIA,
      Stanley
