Greetings !
I must be doing something wrong cause the fillet feature usually fails everytime i try to use it. (SolidWorks 2011)
I can fillet the edges of a cube but that's pretty much it. ( Being sarcastic here !)
I just made a model of the Icon A5 aircraft and as you can see from the picture below, the edges near the nose are just rasor sharp... (See around the headlights0
UPDATE: The complete model is about 112Mo so i uploaded two shorter versions so that if anyone wants to try to apply some fillets on those edges that would be great... Of course, i would just need to know how to do it.
- "Fuselage-2" (12Mo) just containing the surfaces used to create the fuselage solid body.
- "Fuselage-3" (2Mo) which is the first solid body version of the fuselage in my features tree.
Thanks !
Tod,
Haven't downloaded your model, but have you tried/know how to use the Variable Radius Fillet?
Paul
