This is a downloaded sketch from a CAD file from a supplier.
How do I quickly resolve the sketch so I can revolve it? There are
so many irregularities with it that it will take me forever if I
have to check out every line and intersection.
If you edit the sketch you can select all the entities and fix them
Use the 2d to 3d toolbar while editing the sketch to align any selected point with the orgin.
You can use the sketch tools / modify to rotate the sketch.
I made a drawing with the sketch and saveas a DWG file.
Then imported the DWG using... insert > DFX / DWG... NOT copy and paste from Acad.
MERGE POINTS... Very Nice!
