1 Reply Latest reply on Mar 29, 2014 1:18 AM by Simon Turner
    Determine Intersection Coordinates
    Nick Baker
      Hello all,
      Will one of you please help me locate the (X,Y) coordinates of two intersecting entities? Here is how I'm creating the entities:
      Set swSketchSegment = swSketchMgr.CreateCircle(0, 0, 0, 0, PD / 2, 0)
      Set swSketchSegment = swSketchMgr.CreateEquationSpline2(Xeq, Yeq, "", ".3", ".4", False, 0, 0, 0, True, True)
      I realize that I might have to utilize InsertReferencePoint, but I'm not sure how to select the 2 previously created entities.
      Thanks in advance,
      Nick
        • Re: Determine Intersection Coordinates
          Simon Turner
          Just get the ICurve entity from each SketchSegment and then use IIntersectCurve.
          Something like:
          Set swSketchSegment1 = swSketchMgr.CreateCircle(0, 0, 0, 0, PD / 2, 0)
          Set swSketchSegment2 = swSketchMgr.CreateEquationSpline2(Xeq, Yeq, "", ".3", ".4", False, 0, 0, 0, True, True)
          Dim myCurve1 As Curve
          Dim myCurve2 As Curve
          Set myCurve1 = swSketchSegment1.GetCurve
          Set myCurve3 = swSketchSegment3.GetCurve
          'Need to find end parameters of the curves:
          Dim u1 as Double
          Dim u2 as Double
          Dim u3 as Double
          Dim u4 as Double
          Dim isClosed as Boolean
          Dim isPeriodic as Boolean
          myCurve1.GetEndParams u1, u2, isClosed, isPeriodic
          myCurve2.GetEndParams u3, u4, isClosed, isPeriodic
          Dim res As Variant
          res = myCurve1.IIntersectCurve(myCurve2, u1, u2, u3, u4)
          'Resulting intersections (if any) are stored in res
