3 Replies Latest reply on Apr 3, 2014 1:04 AM by Val Blant
    Noob question
    Val Blant
      I just started learning SolidWorks, so my question is likely very simple. I need some help designing a cone with "teeth" cut outs at the base. It will need to be a 3D version of this 2D picture:
      http://i296.photobucket.com/albums/mm185/vace117/cone2d.jpg
      The only idea I have so far is using the Wrap tool and then ebossing the teeth patern all the way through the cone walls. Will that work?
      The part I am not sure about is how to match the size of the teeth sketch to the size of the cone. Obviously the width of the unfolded cone can be calculated, but I am sure that SolidWorks can do this calculation for me... I am also not sure how to create a Sketch plane that would be tangential to the cone.
      Is there a way to start with sketch based on the picture above, and then wrap it around a cone of the correct size for that specific sketch?
      Any advice would be appreciated.
        • Re: Noob question
          Jerry Steiger
          Val,
          To make a plane tangent to the cone, just select the outer face of the cone as the first choice in the Plane. I would probably pick another plane as the second reference and make it perpendicular to that plane. (If the base of your cone is on the Front plane, then I would pick the Right or Top plane to be perpendicular to.)
          I suppose you could use Wrap to make the teeth, but I would be inclined to make one tooth, then use a circular pattern to generate the rest.
          To get the proper length for your tooth, just use pi in your value. If your diameter is 40 mm and you want to have 10 teeth, then the circumfrential pitch of one tooth is 4*pi. Just enter it like that when you define the length.
          Jerry S.
          • Re: Noob question
            Scott McFadden
            Val,
            Looking at the teeth in your picture, they look to be different.
            If they are the same, use one of the base planes and do an extruded cut through all projecting out.  Then do a circular pattern around.
            If they are different, with some being the same, then do a combination of my first suggestion and then create a new plane rotated to the desired angle and do the same extruded cut through all.
            Hope this makes sense.
            And, this is not a noob question.  This can be tricky if you are not familiar with the software.
            • Re: Noob question
              Val Blant
              Big thank you to both Jerry and Scott for getting me onto the right track with this problem!
              Just in case it helps someone else, here's the complete process I ended up with:
              1) Figured out the angular pitch for the deep tooth and the shallow tooth. There are 2 deep teeth and 4 shallow teeth.
              2) Drew contruction lines on the base of the cone and eminating from the center of the cone, with the correct angles for the teeth from step 1. This provided me with intersection points between the base of the cone and the lines.
              3) Made a plane tangential to the cone surface and positioned exactly in the midpoint between 2 contruction lines from step 2.
              4) Drew a triangle for a single tooth, with 2 vertecies coincidental with construction points from step 2.
              5) Did an Extrude Cut.
              6) Repeated steps 3 to 5 for the shallow tooth.
              7) Used Circular Pattern and Mirror Pattern to position the rest of the cutouts.
              Thanks again for all the help!
