I mate a spherical bearing, and isolated moves how i need, but when i put a screw connected to the bearing, using mate concentric, in assembly the movement disapear and the connection appears to stay fixed. How can i solve this problem, i attached the file.
Tui,
You need to make your HPC_-_KGLM-10_2_14b2 assembly flexible. Currently it is rigid & so it won't move. Click on the assembly & select "Make Subassembly Flexible", bottom right icon, that should allow it to move. You might then want to constrain things with other mates as it can move outside of what is phyically possible for the bearing with the screw through it.
