Hi guys
I am dealing with one job, not a big one but there is a flange feature that I am struggling with.
I need to make the same flange on 3 edges and they have to have all 45 ° ending and joining. ( Miter 1 is the right flange profile. )
I can manage the ends but I am struggling with the joint in the top left corner. Its a bit messy now and not what I need to have. I need 45 ° joining each flange.
the same like I have got on the first flange at the bottom.
I was gonna do the miter flange on all 3 edges at once but it says it can not be done on the top edge and I do not know why.
If I want to do that, It shows a little icon ,,Propagate,,.
Would you mind taking look at my part and see what you can do?
Good night and thank you to all of you
hei'ya Fred, see if this is of use for some ideas,
I think the issue is the two flanges are not geometrically true
to each other- one is perpendicular and the other tilted by the 25deg
I'ver modelled from a mold situation rather than a base flange
and used rips to control the surfaces
hope this helps dude- have a good'n kelef
